Well after a year of planning and an entire summer or work, headaches, bloody knuckles, scars, headaches, burnt feet (welded in shorts without socks on), setbacks, and more headaches, I finally got the ZX3 boosted and tuned. I tried to keep this as inexpensive as possible. I know with more time and know-how/practice with welding, etc I could have done this even cheaper than I did. I did manage to keep this under 2K though, and I'm happy about that. Alright, on to the components:
TD05-H 14b turbo
I'm using my stock manifold with an adaptor angled at about 20 degrees
DSM side mount IC (Thanks a bunch Rexified from WVStreets.com!)
1.75" hot side piping (came free with my BOV, thanks TunerToys)
2.5" cold side
05+ Mustang slot style MAF
42 lb/hr green top injectors
Tuner Toys/Stealthmode Performance oil lines
DSM BOV
2.5" exhaust with a trubendz flex and a 4" round Magnaflow straight through muffler
Dyno tune and X3 flash by Lasota Racing (I highly recommend them, they rule hard)
The only other mods I have are a 65mm tb, B&M short shifter, SVT suspension, and Brembo OEM brakes with Hawk HPS pads
The turbo spools slow and only hit just under 10 psi right before they let off at around 6750 rpms. I made my peak power and torque at 8-9 psi in the 4500-5500 rpm range. Not exactly what I was expecting, but it's fine with me. I ended up making 182.93 whp and 188.57 ft.lbs on a 100,000 mi stock motor. Overall, I'm real pleased with how it's turned out and even more so at the awesome job Don and Rob did tuning the car.
Enough of my rambling, here's some pics:
TD05-H 14b turbo
2.5" cold side
DSM BOV
