Seeing that I find myself in rural NC quite often, I would like to upgrade the reverse bulbs with a bulb that has higher light output. Initially, I was going to go with Sylvania Silverstar bulbs, but I've started seeing bulbs that might be brigher.
I'm not up on all of the terminology and types of newer bulbs, so if someone could make a recommendation, that would be great.
The only real requirement I have is that I don't want something that runs the risk of melting the connector due to excess heat from extra output.
This is a nice to have and not a must have, so if the risk exists of melting the connector, I'll stick with a lower output bulb.
Any suggestions would be great.
