1 - 10 of 10 Posts
whenever i starting pushing the brakes down when i'm between 60-80 mph, i can feel the brake petal start to violantly shake. it's not horrible but definately noticeable. i checked my fluid and all 4 pads and they are all good; pads have more then enough material. what could be causing this?
Good chance your rotor is warped.
Real good chance, brake down from [nono] for an exit ramp recently?
^^^ Sorry for the specific number, it was arbitrarily chosen, I'll be more guarded with my 3-digit-numbers in the future [;)]
Besides, as a responsible member of the Focus community, I'm positive richiejerzee4lfe would never exceed the posted speed limit, and in hindsight the noted action could therefor not have caused the rotor warping.
Definately warped rotors, same thing happened to me in college. New rotors, no problem now. Check it out. Guarranty thats it
The Librarian
To narrow it down between front and rear at least:
Use the e-brake only to come to a stop.
Then, brake normally without the e-brake.
If you're "smooth" with the e-brake, then it's one (or both) of the front rotors.
If you get the shimmy when using the e-brake only, then it's the rear rotors that are suspect.
1 - 10 of 10 Posts
