Sorry, I did a search and everything came up with the clutch master cynlinder, not brake.
I have a 2000 Focus SE Sedan with about 188,000 miles on it, I've had it a LONG time and drive 40+ miles each way to work.
Its an automatic with recently new brakes (had all 4 done in the last year) and there is no brake fluid leak (stays topped off).
However, I am beginning to have to depress the brake nearly to the floor to engage the brakes.
I've been told that this is probably the brake master cylinder. I've looked it up and the part is only about $50, but was wondering how hard it was to replace this and if anyone has a good step by step set of instructions to do it.
I am fairly mechanical, just not on cars if that makes sense. I am an engineer but just never worked on my car much.
So my questions are...
1. Does that sounds like the master cylinder?
2. Is it easy to replace or should I take it to my mechanic?
I'm at 188k miles, going to try to make it to 200k before I buy a new Focus.
