1 - 5 of 5 Posts
Have 2005 zx4 need diagram of the complete hydraulic system to locate part numbers for brake lines
You want to order pre-bent brake lines? I wish you luck, but I doubt they exist. I usually buy a coil of brake line, which is easier to bend than the straight sections. Then slide on a fitting (don't forget that part) and flare the end with a flaring tool. Re-use the fittings if they are odd balls.
Just get a roll of Ni-Copp brake line. You won't be sorry. You can do 90+ percent of your bends by hand with good results and the stuff is not susceptible to corrosion like steel. Great to work with and great performance so you won't regret paying a little more for this material.
1 - 5 of 5 Posts
