1 - 11 of 11 Posts
So here's my problem. 2012 focus se. I have checked all the fuses, wiring, etc. When I unlock my car, both brake lights come on. However, once I turn the car on a brake light bulb fault comes up. The rear right light is off. There's been a few times where it will work, but 99% of the time it's off. I haven't changed, let alone touched, the original bulb.
Thoughts?
Rubber Side Down
So you haven't even checked to make sure it's seated properly in the socket? Try that first.
Thoughts?
Sedan or hatch?
The sedan uses one bulb for both parking/brake. When you unlock the doors, the parking portion of the filament is actually coming on, not the brake portion. So you could just have a burned out bulb.
I've come across this same problem. Only, I have replaced the bulb, changed the wiring, and yet it still says there is a bulb fault. Mine is on the passenger side. There are a few time it will work while driving but I get a notification not 10 minutes down the road. Are there any other alternatives?
Did you replace with the correct bulbs?
Were they replaced with incandescent lights, or LED's? LED bulbs could cause and issue like that.
I recently got a new cover for the rear lights due to it being broken and they came with new bulbs. I saved the old ones just in case because they were working just fine. The replacement brake light does not work so I replaced it with the original bulb which is perfectly in tact yet I am still receiving the same message and the light will not work.
1 - 11 of 11 Posts
