1 - 10 of 10 Posts
When I am driving down the highway and I lightly apply the brakes (say to slow down for an off ramp, etc) I get a shaking of the steering wheel. Now if I ever have to get on the brakes hard I don't get any shake and the car does not pull to one side or another. I only get this shaking/vibration if I get on the brakes lightly.
Ideas? I have some guesses but I want to hear yours first.
Oh BTW, 03 SVTF, 43k mi original brakes/rotors.
FoFo Lover.
I would say warped rotors....you can take them to a shop and they can "shave" them down. So they are straight again.
Jetsetter
warped for sure, get new rotors "turing" or "shaving" your rotors is only a band-aid the same problem will arise again, go new
^^^ yup.. do not just shave you rotors if they are warped.. rotors are fairly inexpensive anyways.
Discussion Starter #9
ok, I was thinking warped rotors too, just wanted to get a confirmation....too bad that SVT rotors are retardedly high.
Highly unlikely that they are warped. Real wrapping rarely occurs (read brake articles at top of this section). What you are experiencing is more likely poor/uneven bedding of the pad/shoe friction material into the rotor (caused by the uneven surface density of the rotor which is getting more common with cheaply made rotors) or a little bit of allowable run-out of the rotor. If its only felt under slight pedal pressure I wouldn't worry about it.
1 - 10 of 10 Posts
