The brake saga - - -
The front right brake would become lightly engaged after I started the driving the first time of the day. Sometimes it's not noticeable until I started to hear an extra roar over the road noise. To check it I'd tap the brakes and the pedal would not go down. The brake was dragging, causing the parts to get hot, expand and cause the brakes to come on more. I could tap the brakes but most times that would NOT make any difference. I'd have to park for about 10 - 15 minutes. Things would cool down and I could drive the rest of the day with no problems.
Other times I'd know the brake was dragging because I'd get a vibration in the steering wheel. It would easily be diagnosed as bad rotors. However - stop for 10 - 15 minutes and there would be no more problems for the day. Put on the brakes and it would be like normal, therefore there was nothing wrong with the brake rotor.
All of this causes multiple problems but NO ONE has figured this out! It is a problem that I believe plagues a LOT of Focus!
FIRST - go online and look at how many people have replaced steering wheel columns on Focus'. The replace it because the steering wheel becomes loose. They think the column is bad. My steering wheel started to get loose, it would wobble on the column. I wanted to research the problem. Early in a search about the problem I found this:
http://www.steeringcolumnservices.com/
There is an upper bearing that tends to cause this problem. [
]The shaft can slip out of place during a repair and then the bearing becomes unseated and causes this problem. [
I was ready to order a column, about $400 I think.
I wanted to research more. I ran across the following:
http://forums.focaljet.com/mk-i-interior-modifications/531338-steering-wheel-replacement-how.html
or
http://www.focusfanatics.com/forum/showthread.php?t=99259
or another that I can't find right now that was about changing steering wheels.
As I pulled in to my driveway at the end of a work period (I was starting four days off) the steering wheel skipped - I turned the steering wheel but the tires did not turn! I push the steering wheel down, hoping to engage the steering wheel column teeth and it worked. Wow, thank you Lord!
Since I'd done that research I decided to take things apart to see what was wrong. I wanted to know if I needed to replace the column. I'd disconnected the battery and got down to taking off the airbag so I could see the steering wheel bolt. It was LOOSE! And I don't mean a little! I turned it a LONG time with my fingers! I got the proper tool and tightened it up and BINGO!!!! NO MORE looseness in the steering wheel!
This happened 2 or 3 more times UNTIL I got the brakes fixed and the vibration stopped! Did you catch that? I stopped the brake vibration problem and I had NO MORE loose steering wheel!
BRAKES - It is my opinion no one is sure what causes the brake problem - brakes that start dragging. It is a COMMON problem. Search and Focus dragging brake problem seems to ALWAYS be at the front right!
A first problem is associated with the PCV hose on the Duratec engine. It's hidden under the intake manifold!! I replaced the hose (and the PCV) because it had gone bad just like you'll see online during a search about that! I can't remember exactly but it was something about a vacuum leak affecting something which made the brake engage.
Everything was within the front brakes so that's where I replaced parts. I believe I replaced the rotors and pads but after a while the brake vibration came back. I then replaced the front brake calipers AND brake lines. With the pads dragging a LOT of heat builds up. Brake lines are really two tubes in one. That inner liner/tube may buckle inward and not let fluid flow thru like it should. I think I also replaced the master cylinder during this time.
The vibration disappeared!
WHAT EVER ALLOWS THE BRAKE PROBLEMS TO START CAUSES ALL THESE PROBLEMS.
Here I am one year later - - my front right brake pad is gone and I'm getting gouges in the rotor!! The other brake pad has very little wear on it.
I want to replace ALL the vacuum hoses - especially the booster hose and vacuum brake booster check valve. I'm not sure but I may consider replacing the caliper again.
Has anyone found a solution??
Much thanks,
bamakodaker
