Yes. The Focussport is a "pusher" and the mityvac is a "puller." lol. With the focussport you fill it with the brake fluid and screw the other end onto the resevoir. Then you pressurize the main part which will create a positive pressure in the resevoir. I usually do around 10 PSI. Then all you have to do is go around to each wheel, open the bleeder valve and wait for it to start coming out clean, close it and move onto the next wheel. Easy as pie.
The Mitivac, commonly called a vacuum bleeder works by creating a vacuum inside a catch can attached to the hand pump. YOu attach the bleeder hose to the bleeder valve and pump up the hand pump creating the vacuum in the catch can. When you open the bleeder valve this vacuum, trying to reach equal pressures with the outside will pull fluid through the system. Just make sure the resevoir cap is off and you have someone filling it occasionally. Both are very easy methods. I just like the pressure bleeder myself.
If you do get a vacuum pump, get the more expensive one. It will be made of metal instead of plastic and is much stronger. I had a plastic one once that was garbage and broke after a couple uses. The metal one is much better.
