Ok well while driving the abs and brake lights flash on and off. When checking scan tool it comes up with brake fluid low. The brake fluid is full. I can't find the schematic for the brake fluid sensor wiring anywhere. It not on any of my schematics like it dosen't exist. The voltage at the sensor keeps changing when testing with a multimeter. from 2-12 volts. something dosen't seem right there. I don't know if it comes from the abs module the ecm or what or what the voltage is supposed to be. I know the float is good
I tried searching but every one just says check your brake fluid .
