1 - 10 of 10 Posts
I noticed my head lights were out. I checked the fuses under the hood and they were all ok. I then replaced both bulbs and they still don't work. What am i doing wrong here? What am I missing?
Thanks for the help!!
ELVIS LIVES !
Check the connectors and make sure they are lined up and making good contact. That is what the bulbs hook up to. Also check the metal pins coming out of the bulbs to make sure they also line up.
ELVIS LIVES !
It may also be in the light switch itself if the above does not work.
Both high & low out?
Did you identify the fuses by diagram? (not sure where yours are, there's also an interior fuse panel)
Look for a relay in the system? Swapping with an identical not currently in use is a quick check for those.
Next step after Godzukidan's checks might be checking for power/ground at the plugs with a meter.
ELVIS LIVES !
Yes the fuse box is behind your cd holder built in your dash. You will have to take the cd holder off to get to it.
Vince your Moderator
There is a relay also.
Discussion Starter #8
Thanks for the reply's. I will take a look at the fuses in the car right now. Well after my coffee. :)
Discussion Starter #9
Got it fixed
There was a problem between the steering wheel and the front seat :-D
ELVIS LIVES !
[twothumbs] LOL happens to me a lot. Glad you got it fixed.
1 - 10 of 10 Posts
