1 - 3 of 3 Posts
i need to installl a saftey blow down tube on my nitrous kit so i can run it at a track. i havent got it yet its on the way. 20 bucks at jegs. anyhow im gonna need help installing it since i dont even know where it goes?????? i think its in case the tank bursts and it vents the gases outside instead of inside the car making me loopy, in which case it should go on the burst disc right?????
Discussion Starter #2
wow! dont everybody jump in at once!
FF Affiliate
Correct if you have a later style tank it should have a place to just screw the blow down tube onto , this MUST be vented out side the car through the floor board , you can cut it as needed or bent it as needed but it muct be at least 2 inches through the floor
It isnt to keep you from going loopy it is to keep you from blowing all the windows , trunk , door skins off the car
1 - 3 of 3 Posts
