1 - 6 of 6 Posts
Hi, Just joined the forum. Hope you can be of help i have a 2012 focus sel my touch screen went black so i'm guessing the apim has gone bad i located a used unit with the same part number as my apim if i install a used unit will it be plug and play or will i have to go to the dealer to have it programmed to match my vin number? Hugh
2016 535D
Hey I just had the exact same thing happen. I plugged in a used apim but not with the same number so it is not working properly and will have to be programmed. Yours should be plug and play.
Here is an update on my black screen issue.I was able to find an exact replacement on e bay, matched up the model number to the module in the car. Installed it this morning and it booted right up, as a bonus i now have nav. For $220.00 i'm back in business. It's important to match the model number on the back of the module exactly. Hugh
2016 535D
I have an update for the cheapskates! I bought a non matching apim because it was only $50 and I could not find an exact match. This one was from a focus but with different options. I was able to get it to work after reprogramming it to my vin spec using FORscan.
1 - 6 of 6 Posts
