1 - 3 of 3 Posts
So I recently replaced my original shocks on my 2013 focus SE with bilstein B6 "heavy duty" shocks. Well, first I replaced them with koni FSD's (discontinued) and got all the way through the job just to discover they sent me two right side front struts. Luckily returned for a full refund. Then I purchased the Bilsteins, and tried using them with 2013 focus st front springs, Moog p/n 81600. Rock Auto shows them as fitting a 2013 at, but not a 2014 st, so I figure they should be the correct style of spring. Anyhow, when I put those on the front suspension barely compressed. It was like a 3" lift! So, back at it, I swapped those springs for the OEM springs.
Now, curently with these high pressure gas charged bilsteins, the ride height is approx 1" taller f/r than it was before/other focuses. This definitely had a negative effect on handling. Body control is good but grip is down. I would be fine with stock ride height or up to 1" lower. Shod I buy steeda lowering springs? Should lower the car 1"f, 0.8"r according to them. Thinking this probably will result in stock height? Anyone with experience?
2006 ZXW SE, starting its new life as a sleeper
You could always cut the ones with the rate and feel you like (the ST springs). A harder than stock spring is going to bottom out like a cut stock spring.
I loved the shoe test btw.
1 - 3 of 3 Posts
