21 - 24 of 24 Posts
got your spacers installed up front & spindle brackets in the rear ( + my 1.25" subframe spacers), looks good!
now i just gotta drive it a little then get me alignment done.
Also I need to lengthen my e brake cabe, about 1". any ideas on an easy way to do that?
Discussion Starter #22
No need to lengthen the cable.
You can modify the e-brake handle. Where the cable adjustment nut sits on the e-brake handle, cut that back about a 1/2" or maybe a little more and everything should work fine. I'll get a pic posted for you
Discussion Starter #23
Use a dremel or angle grinder etc. to cut away the area marked in red
21 - 24 of 24 Posts
