Looking for interpretations/advice. I have a 2012 SE sedan with 2.0 liter & DCT. It has 74,655 miles. Six days/372 miles ago I changed the oil myself with Penzoil full synthetic 5-20 and a Bosch 3300 filter. It was a "deal" from Autozone. It is their specified filter part number. I am an experienced do it yourselfer. The filter seemed smaller than other brands. I installed it the way I always do. Coated the gasket with oil and pre-filled the filter. I did it hand tight then 1/4 turn with the wrench. I checked it after. No leaks, oil level correct. Last night on the way home from work about 2 miles into my ride I heard a "pop" and the oil light came on. I stopped when safe about a mile. The oil filter was burst and was gone-oil everywhere. Nothing on the dip stick. I had it towed home.
Today I replaced the filter with a new Motorcraft FL910S and Mobil 1 5-20. The car starts and runs but rough with ticking (sounds like valve train noise). Very low on power. Initially there were no codes or CEL light. No oil light. After a test drive I disconnected the battery to clear any codes or try to reset "limp mode." After I did that, then the engine light came on. I took it to Autozone to read the codes: P0087 (low fuel pressure), P0012 (variable valve timing/over retarded) and P0014(VCT oil control solenoid,camshaft position). Those are my interpretations on the code from the search feature here & AutoZone's printout.
I am out of factory warranty. I do have a half assed after market extended warranty but I anticipate a battle for coverage seen how I did the oil change myself.. I'm trying to diagnose and weigh my options. I think valve train/variable valve timing damage. My options: dealer service dept. would be most knowledgeable but expensive. Independent mechanic cheaper but might not have specific special tools, diagnostics etc. What about used engine or head/valve train assembly? Any ideas or advice?
