k, i have been working on a battery relocate for the SVT. i already took the space from the front with other items, so the battery WILL be going to the rear. I will be making a custom battery box from Lexan.
I have 1/0 welding cable running underneath the car from the hatch to a space near the starter.
I will have a 200a circuit breaker between the battery + and the starter. This is located withing 12" of the battery.
The 1/0 cable will be ran directly from the circuit breaker to the starter. without breaking the cable, it will be ran to the alternator. (although, there will be a 175a fuse inline here to mimic the OEM setup).
All Charging cables will be replaced with this 1/0 cable.
I HAVE AN OPTIMA REDTOP!!!
Now i have a question or 2.
I need a new alternator too cuz the old one gave up. Will a high output unit be needed to compensate for the extra distance between the alternator and the battery?
i only have a 250w amp in the car. nothing serious. but i MAY add something down the line. nothing larger than 1000w though.
can the positive lead that goes to the fuse block under the hood be directly bolted to the terminal on the starter? If not, i can install a d-block, but i really dont wanna.
i will be installing a remote + terminal under the hood. can this be connected to the starter as well?
please discuss. is there something wrong with this proposed setup?
i hope this thread be more knowledgable than other threads that just die off.
