1 - 7 of 7 Posts
Id like to eliminate or put on a high flow cat on my 06 ST. im looking for the easiest and least expensive way, without setting off a check engine light if there is a sensor after it. I dont have emmissions in the county i live in, so that wont be an issue
thanks in advance
thanks in advance
Actually, if you REMOVE your cat you WILL have a problem. Even though you do not have to pass an I/M inspection out in Windber you are subjected to a "visual anti-tampering inspection" as part of your safety inspection. The removal of your CAT will cause you to fail and you will not get your safety sticker.
does the second cat cause a lot of restriction? jw if I should cut out my second cat or not.
slow
That sucks.
w/ my magic bag
Manifold/converter is all one!
thanks in advance
Your converter is part of the manifold! So if you want to elimanate your converter that mean's, you'll need a header & a flex pipe! You can elimanate the smaller converter after the flex pipe, w/ no issue's thou. Out of all the foci, manifold/converter set up, from what I've seen, the ST's combo is the best flowing, compared to the log style on the 2.0L's. If you go w/ a header/flexpipe combo, it is best w/ a tune= you can turn off the check engine light! I would probilily say it's going to be louder, so it would be work best w/ Focuswerk's "Stealth" system. To do it right the 1st time is going to cost 'bout $400-$500= do it once, & be done w/ it!
1 - 7 of 7 Posts
