1 - 20 of 32 Posts
Shot me 3 deer!!!
haha, definitely not an UDP!! no hp in that. go w/ a good set of cams gears and all boltons.
FF Affiliate
What are you thinking cam gears will add ? agree UDP a waste of time much like the cam gears , coils , wires
A tune will help you come then help more as you do other mods
I.S.A.I.K.I.
Making a switch to fully synthetic motor oil and transmission fluid (like I sell. Link is in my sig) will definitely reduce friction and you'll see gains on your next fill up.
Token Engin-nerd
yes if its an auto and its never been changed, drop the pan and change the trans filter
i gained 3 mpg just by doing that at 137k for the first time (PO sucked at PM)
otherwise i would say a cheap short ram intake, will give you MPG and a bit of power.
1. Tune
2. SRI or CAI
3. Exhaust
Shot me 3 deer!!!
Sorry Tom, I forgot comma's, "Cams, Gears, and boltons"
Sooooooooooo EURO
if its an automatic then a tune and a full exhaust (header/flex/catback) would be your best bets for increasing power MPG and sound :)
C2H5OH
Reduce the weight of the vehicle.
Reduce rotating friction.
I need BOOOOST!!!!!!
the best bang for your buck to up the power is nitrous hands down. it can be dangerous if not done correctly but its the cheapest power upper that actually piles on the power. for fuel econ and a little more power get an sct xcalibrator 3 and talk to tom for a tune.
This was in today's paper from Mazda:
MAINTAINANCE ITEM-----------------BENEFIT-------------------------MPG INCREASE
Properly Inflated Tires----------------Proper Rolling Resistance-------------1-2 MPG
Clean Air Filter-----------------------Proper Fuel/Air Mixture----------------2 MPG
Properly Functioning Spark Plugs------Efficient Combustion/Limit Fuel Waste--2 MPG
Properly Functioning O2 Sensor-------Detects And Adjusts Air/Fuel Mixture---3 MPG
Clean Engine Oil----------------------Minimizes Internal Engine Friction-----.4 MPG
Don't know where Mazda got their info. but, it's interesting. At Ford we were told that an internal combustion engine is, basically, a big air pump. Air is sucked in and pumped out. The "Clean Air Filter" screams of adding an SRI or CAI and, assuming that they allow more air into the engine, a better exhaust would follow (more air in- more air out). This, followed by a good tune, would seem to fall into Mazda's guidelines and, common sense!
there can be a minimal increase but for the most part
performance and economy are trade-offs.
1 - 20 of 32 Posts
