1 - 17 of 17 Posts
Ok i know iv seen a dyno forum on here comparing all of the dyno's but i cant find it. I just want the best bang for the buck i was looking at the Steeda but its 299 and the Fswerks with the green filter is 159 there is quiet a big difference there so i just wanna know if its going to be worth it or save the 140 and buy something else with it
I would do FSWERKS CAI and get a rear sway bar. Just me.
#dailydriven
the thread that compared them all showed the K&N putting out the most power i believe. +1 ^^ on what he said too.
The ImpoSTer
Love my K&N. It actually replaces the stock intake hose too.
Love my k&n but it's loud
Does it give you a gurgling sound at low speed/heavy load like the open-end COBB filter (for example) or running without the air box cover? I tried the Injen and the COBB and removed them shortly after because they sounded ridiculous. Trying to find something that sounds good and not stupid, but I don't feel like wasting the money to try them all.
Just grab the open-end K&N drop in. Small noise increase but not anything obnoxious.
The best bang for your buck is a K&N drop-in and remove the snorkel. <$50.
I should be getting in my AEM CAI tomorrow morning and will promptly be calling in sick to work just to put it in. After what I have read and seen it is the only intake to actually draw from below or away from the engine compartment.
I'm pretty sure i've seen somewhere that said the AEM CAIis the only true CAI bcos it does exactly that ^
I don't know much about CAIs but to me I feel like the K&N CAI and the Steeda CAI (for the ST) are designed to gather air from the front // have channels or heat shields leading up to where the snorkel hose would be. If the Steeda CAI for the NA had a similar style box as the version for the ST combined with the Ram Air. I feel like that would do an extremely good job at pulling cold air from the outside. Or am I wrong? :p All the rest seem really open, but don't have a direct channel to a cold air source?
(Pretend the Steeda ST CAI fit the N/A)
The stock box is a true CAI as it only draws air from outside the engine compartment.
yea that too.
I'd just go with the Drop In & Snorkel delete ($50?) and maybe adding the Steeda Ram Air Intake Scoop ($140) after. Total (< $200~).
All together still cheaper than other CAIs listed ($250-300 + ?). The Ford Racing Cold Air Intake Kit is similarly just a high flow K&N Filter + Air inlet.
not sure of the performance gain differences tho
Does the ford racing air inlet even work on a non st? Seems like it might go down enough to contact the bumper cover.
^^^Folks here have used it successfully; do a search on "ST snorkel".
Ahh thanks. Well I won't be spending the $175 for it anyways. I don't see it doing too much more than the regular piece + a drop in.
1 - 17 of 17 Posts
