Last night, I installed a front stress bar on my focus sedan (in the dark). I took it for a run up and down the streets and handling felt somewhat stiffer than stock when cornering hard. This morning, I drove to school and was a little hard on the steering around corners (which is normal for me). Just to be sure everything had remained bolted tight, I decided to do a quick check-up. To my dismay, i noticed a larger gap between the hood and the frame on the right side (passenger side) than on the left side. The hood is slightly below the frame on the drivers side and slightly higher than the frame on the passenger side. I am sure about the gap discrepancy between the two sides as I tested the width with my pinky finger. I can stick the end of my pinky finger all the way under the hood on the passenger's side. HOW DID THIS HAPPEN?!!?!
