From a cold start and since having my timing belt done in August, my 02 Focus has developed a bad vibration and noise from the front right side. I had my sway bar links and tie rods changed as per recommendation from my Ford dealer. It gets worse as revs increase up to 4000rpm (4th gear at 60mph/100 kmh) and also on right turns on 'on ramps'. It worsens over undulating surfaces, disappears when out of gear and coasting and disappears when the engine has warmed up. Could the passenger engine mount have been damaged during removal for the timing belt? Any help from you would be appreciated. Cheers from the Woodchuck Cider drinking English guy.
