OK,my other thread was moved from technical to zetec performance and I cant wait for a mod to move it back.
Car is an auto 2002 zx3.
Mods are 65mm throttle body,Steeda Short ram,Focus sport 4-2-1 header,no cat,2.25 Flex and custom exhaust.
After Header install I got code p0171.
Changed collapsed pcv tubing and pvc valve.
Reset ECU.
Shortly after I got code P 1406
I cannot find any vacuum leaks or header/exhaust leaks.
What are the symptoms of a EGR system going bad?
My idle still isn't 100 percent,although after changing the pcv items,its gotten better.
The Car still bogs on off the line WOT.
I dont feel the typical DPFE flutter while cruising but at times do hear what sounds like a angry lawn mower exhaust leak,but it isnt coming from the exhaust.
I can also smell gas or oil or exhaust fumes periodically.
Could this be the EGR valve stuck or maybe a hole/split I cant find in the tube?
I need input fast Guys....
If this is indeed somehow EGR related,Im going to get my tune by next Friday and disable the EGR system.
Hers a link to the other thread with pics of everything that happened and what I have done so far.
http://www.focusfanatics.com/forum/showthread.php?t=266030
Mods I apologize for posting about this again,but have emailed several mods to move my original thread and it hasn't happened.
Becoming desperate as I dont know if driving the Car (daily driver) with this CEL is harmful.
Input seriously appreciated.
Reset ECU.
