1 - 4 of 4 Posts
Ok, so recentley my rear brakes developed this odd problem. When the car has been parked all day and overnight in my garage (open garage) I get this grinding/scraping noise from the rear. It'll go away after I depress them a time or two. I just replaced the drums 4000 miles ago and I don't drive like a bat out of hell. It's especsially bad if the last time I drove it was in the rain or I washed it the night before. It's got 58K miles on it and I dont think the rear shoes have even been replaced. What could be the problem.
Sounds like a typical problem that most Focus's Have. First check your brake lines and try and lossen them up by pullin the line next to the drum and seeing if it loosens up and if you want the real solutions hopefully this will help.
FORD: 2000-2006 Focus
This article supersedes TSB 05-10-5 to update the service parts and model year coverage.
ISSUE:
Some 2000-2006 Focus vehicles, produced before 01/20/2006 (excluding vehicles equipped with rear disc brakes), may exhibit a squealing noise from the rear drum brakes during stopping.
ACTION:
Replace the rear brake shoes with revised components. Refer to the following service procedure.
NOTE: SOME 2002 AND PRIOR MODEL YEAR VEHICLES MAY ALSO REQUIRE WHEEL CYLINDER REPLACEMENT IF THE REAR BRAKE SHOES ARE BEING REPLACED WITH THE REVISED COMPONENTS. REFER TO THE FOLLOWING SERVICE PROCEDURE.
SERVICE PROCEDURE
Remove both rear brake drums. Refer to Workshop Manual (WSM), Section 206-02.
Inspect wheel cylinders
If the wheel cylinder housing is bare cast iron then replacement is not required if revised brake shoes are being installed.
If the wheel cylinder housing is plated then replace the wheel cylinders if revised brake shoes are being installed. Refer to WSM, Section 206-02.
Replace brake shoes with revised components. Refer to WSM, Section 206-02.
NOTE: THE REVISED BRAKE SHOES MAY MAKE AN INTERMITTENT SLIGHT SQUEAL NOISE FOR THE FIRST 100 TO 150 BRAKE APPLICATIONS. THIS IS NORMAL OPERATION.
PART NUMBER PART NAME
6S4Z-2200-B Kit Brake Shoe/Lining
6S4Z-2261-AA Wheel Cylinder
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
061307A 2000-2006 Focus: Install Revised Rear Brake Shoes, Includes Time To Inspect Build Date, And Wheel Cylinders (Do Not Use With 2000A, 2001B, 2001B1, 2001B9, 2780B) 1.7 Hrs.
061307B 2000-2006 Focus: Install Revised Rear Brake Shoes, And Wheel Cylinders, Includes Time To Inspect Build Date, Wheel Cylinders, And Bleed The Brake System (Do Not Use With 2000A, 2001B, 2001B1, 2001B9, 2780B) 2.3 Hrs.
It's not a squeling noise though...
If you disagree with that then try and pull your rear drums off or go to your garage and let them do it. Best way is to take the 4 BOLTS off in the back of the drums then they come off all together and can inspect everything you need.
1 - 4 of 4 Posts
