Ok i have an automatic and what i want to know is , is it bad for the transmission or any other part of the car to hold the break and push the gas enough to get it revving but not lurch forward?
how much is a transmission cooler?Zyghot said:It's not bad for it as long as you don't hold it there for a real long time. Just don't take the RPM's too high up, since you are most likely still running the stock torque converter(wich probably has a stall around 1300 rpm's, although i'm not sure on that). If you do plan to brake boost your car alot, I suggest you consider buying a transmission cooler for it since it will over heat if held at high rpm's for too long.
They can be bought at a local parts store for about $80. And it never hurts to have one since your transmission will hold an extra amount of fluid due to it.Bboy mR. SuAvE said:how much is a transmission cooler?
