1 - 6 of 6 Posts
Lockout ring not working? Cable came off?.. I am assuming it is a stick ?
If an auto...?? don't know
Not going into reverse...as in you can't physically pull the gear select past park, or you put it in reverse and nothing happens, as if its still in park? I'd suspect either the interlock that prevents you from changing gears without the brake pedal down isn't working, or else there's something wrong with the transmission if reverse is the same as neutral and everything else works.
Discussion Starter · #4 ·
I have an AtX. I got some work done on the tranny and the shop forgot to connect a wire. Problem solved.
Nice that it was that easy!
1 - 6 of 6 Posts
