I have a front set of used Yellow koni's and I'm considering replacing my
Sensatrack fronts with these, using the stock SVT springs (I replaced all shocks/struts and springs about 25K or so ago along with sway bar links, outer tie rods, upper support bearing etc. (control arms w/ bj were replaced earlier).
I'm trying to get a slightly stiffer front but still having a decent ride for a DD.
I know I can use the lowest setting on the front struts; is this going to be a good match up with the stock SVT springs? Or, should I just leave it as is.
It is equipped with 16" wheels, p6+ tyres of the stock size. (It's an 04 ZX3 premium w/ 2.3 and manual trans), frnt and rear Eibach sway bars. Otherwise, basically stock except for minor upgrades. Any thoughts or guidance on this...
