1 - 3 of 3 Posts
I'm piecing together a turbo system to run 6-7 psi and my question is regarding the use of the apexi s-afc or s-afc2 for the fuel enrichment along with a new maf and bigger injectors, and using a msd 6BTM for the boost retard. Is there any reason why this won't work? I've done some googling and didn't find too much except something about the ecu relearning the stock fuel curve somehow but nobody explained it any further...
Any replies to point me in the right direction are greatly appreciated.
You cannot use a 6BTM b/c the focus uses a DIS ignition system. If you don't know already standard ignition and DIS are not compatible.
oh, that's cool then, thanks for the reply, I'll use a dis btm now. Does anyone know anything about the safc?
1 - 3 of 3 Posts
