Ap dampers dont fit
525 6
Can anyone help me aparantly according to ap these are the correct dampers yet when i put the metal spacer on the shaft there is not enuff thread showing inside the boot area to screw the top nut on i dont know if the gold plate has got to be drilled bigger so it sits on the black metal ring below or if they are actully the wrong ones
1 - 7 of 7 Posts
slow
You may have to drill the plate, on konis, you have to drill the center hole out a little bit.
1 - 7 of 7 Posts
