1 - 4 of 4 Posts
Can anyone elaborate what "slight" modification needs to be done to the splash guard in order to fit the cone filter in there and still have everything align properly with the FC CAI? It just doesn't seem natural how the intake is pulling on the splash guard so the top end of the intake can reach the throttle body. Do I have to cut the access hole larger or what? Thanks!
Yeah that is about all...I have the Marcy Intake and you just cant put all the screws into the splash guard without enlarging the opening a bit.
Make sure also that you do not have all the hose clamps tight before you install allthe way it allows you for a little more movability. I made the mistake the first time then when you have everything at the right angle go back and tighten everything up. Mine too did not match up right with the throttle body at first but after I lossened everthing it lined up fine the I re-tighten. I have the FC CAI and I love it
1 - 4 of 4 Posts
