1 - 1 of 1 Posts
I just got all of the Diode Dynamics LED bulbs for the exterior of my 14 Focus. My problem is that the resistor required to install the front and rear turn signal bulbs apparently gets super hot when the blinkers are used. If anyone else has installed the LED blinkers with resistors, where did you mount the resistors? Right now I have the front resistors inside the headlight itself since all of the wiring in the headlight is more or less contained within the assembly. I’d hate to fry any of the wiring because of a hot resistor and have to replace the headlight, but I also can’t think of a way to mount the resistor outside the headlight without risking moisture and condensation building up inside the light. Any help would be greatly appreciated
1 - 1 of 1 Posts
