I painted mine to match. TAKE UR TIME OR YOU WILL BE KICKING YOURSELF IN THE ASS IF YOU MESS UP!
Molding has double sided tape on the back so you can just SLOWLY take off the molding. If you try to yank it off you will end up bending it and will have a crease in your molding. I used a razor blade to get the old tape off on the car and the back of the molding. Don't worry about scratching the paint on the car because the newly painted molding will cover it. Prep your moldings using
Prep All to remove oils, wax, etc... Sand it with 400 grit sand paper to start. Once you get a decently smooth finish, clean it again....and again. Spray
Bulldog Adhesion Promoter, on your molding so the paint will stick. Lay a few coats of primer down. Sand with 800 grit. Clean it again, and again. Lay a few more coats of primer. Sand with 1000 grit. By now you should have a very smooth finish. If you want lay one more coat of primer down and sand with 1200 grit paper and you should be just about ready for paint.
Start you paint coats with a few light coats. Let dry for about 10 min in between each coat. Lay your final coat of paint and let dry for a long time. Then finish with clear coat the same way you laid your color coat down.
Like I said, TAKE YOUR TIME. Here's how mine came out:
