I just started out modding this car, but one of the first things I wanted was to run a straight E85 tune. Now I know that the flex fuel thing is OK from the factory, but factory E85 tuning is hardly optimized for running on this fine "race-gas for the street" fuel. Needed more timing!!! Torrie said he added a bunch of timing in the base maps, but after some logging and test drives the car is seeming to like +4 degrees global added on top of that!!! After trims settle down I'll send him some logs to make needed adjustments. There could be more lurking!!!
MPG's: For comparison, MPG dropped to about 24-25 for the first full tank of E85 on the stock tune. The first tank with Unleashed tune was 28, and this morning with +4 degrees global I pulled an indicated 35 MPG (been within 1 MPG calculated vs indicated on the dash so far). 90% highway driving for me, running about 4-5 MPH over speed limits with cruise set on fairly flat ground, full throttle entrance ramps though! [driving]
Before I get a dyno run to see what she's putting down, I'm going to at least wait until I get a header and MS3 catback put on. Until then, I know I'm putting down more power simply by first gear runs on the same "test track" near my house. 1st gear has no issues with stock tune, with E85 tune (even without any added tweaks yet) 1st gear flashes the traction control at me and the bog between 1st and 2nd shift is gone. This is roll-on to flat foot i.e. clutch fully out, then flooring it. #progress [twothumbs]
Dyno charts asap!!! should be a nice boost in hp compared to the 91 octane tunes ext. But I've never seen a n/a e85 tune before. But The tune would def help a boosted car more I ran a e85 tune in my evo it allowed me to run. 28 psi with no problems it added a nice amount of free cheap power comes out to be 100-108 octane pretty cheap for racing fuel. The reason I don't have a tune is because I can't run e85 but I guess I can now thanks for the swell news sir
I ran corn fuel in my 2003 Silverado SS and could run about 3-4 degrees more timing across the board with it and pull 21-22 mpg highway, which was 2-3 less than 91 on that vehicle. With nearly 1.00 difference in gas vs. e fuel, the cost per miles goes down with that small of difference in MPG. Hoping to achieve the same thing here. The key is optimizing the tune for full time e fuel.
There is NO E85 that will test 100-108 octane , Dont believe that have some tested , I did , its junk wouldnt run it at all
E85 doesnt have a rating at the pumps because they mix it with such junk no 2 batch are the same , you shouldnt run E85 or tune for it is my opinion
Can I see your results because I can send you dyno results all day from tons cars and articles proving that e85 tuning is legit maybe you got a bad batch .how about Google e85 vs 93 octane. I mean my evo was tuned in house by ams on e85 one of the best evo tuning companies in the land... They wouldn't tune cars on it if it didn't work
I've never had any issues tuning for it since 2003 and never had any tests vary beyond any other fuel specs. They blend it with 87 octance, just like any of the other e-blended fuels. Perhaps the "crap" in your area due to poor economy of the e-fuels themselves, but around here it holds true to 103-105 octane race gas.
I have had it tested , I own my own Dynojet dyno and I can show you just as many articals about how bad it is and how many engines it has blown
I not like most on here that articals said , my friends buddy said , the dyno shop said , I have tested it because I wanted it to work , IT DOESNT , its NOT mixed with 87 fuel if it was it wouldnt cost less then 87 , it takes more fuel to get the job done and in the end it cant
E85 is NOT 100+ octane , it gets its octane effects from cooling the charge not just that it is suppose to have a higher octane rating , I love the guys that dont understand E85 but want to argue about it , run what you want its your engine , I wont run it or tune for it .... I know how bad it is first hand by using it and testing it on and off a dyno
If it makes you feel better then run it , why should I care
I run it because I have tested it, on dyno and off dyno. If there's anyone that doesn't understand E85 here it is you. You said yourself that you couldn't make it work, while so many others in the world can and do. The only engines I've seen blow on this fuel are ones that ran too lean due to improper tune, or adding too much timing too soon. E85 can mask detonation to a point where you can add too much timing and not know it unless you start at a low point, work your way up, then stop adding timing when it stops making power, maybe even back off a little bit. Guess you better tell Koenigsegg to stop making 20% more power on E85 than with gas in their CCXR!
It is true that the natural chemical octane levels of E85 are much lower like 94-98, the EFFECTIVE octane of the fuel is 100-108 because of the higher volume of fuel required to release the same amount of energy. THAT'S A GOOD THING! [ohcrap] Typically about 35% more fuel is needed from my testing to run the same HP levels. But then you add more timing and more fuel and you could be running as much as 50% more fuel at even higher HP levels after you take advantage of that higher effective octane. You can run a non-E85 compatible vehicle on E85 without a tune by simply swapping the fuel injectors for 35% larger ones, no other changes provided the fuel pump is large enough to supply the larger injectors properly. I've done it on several cars and the state of Iowa has done the same thing on several fleets of vehicles (DOT, Iowa State University vehicles, state officials, etc).
Which by the way, the addition of 35-50% more fuel in itself cools the charge, plus the ethanol burns at a slower/cooler temperature than gasoline. Those two things are where the cooling effect comes from.
It is ABSOLUTELY mixed with 87 petroleum fuel! Just like 89 octane mid grade is 10 percent ethanol (or e10) mixed with 87 octane fuel. Blender pumps are also gaining popularity here in the midwest to automatically blend the fuel right at the pump. I've been to the local bio fuel facilities, taken their tours, had them as customers. I've seen the whole process from grain and field debris delivery all the way through to the final mixing and holding stations. The reason it's cheaper is because the ethanol is subsidized to promote renewable resources until the process reaches a sustainable level of its own. And that's really only here in the US, Brazil has had E100 available at the pumps for over a decade and it's totally unsubsidized and proven to work.
This is true I had to buy pretty big injectors for my evo but I saw a 27 hp increase and 30 tq went from 20 psi to 29. I guess we will see when his dyno results come out the truth shall set you free
Yeah, whether or not it's going to prove to be worth a darn on a NA Foci I am still working out. Not even really going to push the tune yet until the exhaust gets done anyway. MPG is settling in to just above 30 for now. Going to revise with a few more degrees timing at cruise to see if we get any more improvements in MPG, then be done until after the hardware changes. WOT we look OK on, might need to change some fuel settings but we're still letting the trims work themselves out before we make any changes.
Would that even work with a 93 tune? I am guessing yes since e85 is supposed to have more octane? Tom would u even recommend this with your tune? I am assuming thats what he has.
I am nervous as well. I was about to put e85 today just to try it since my car is flex fuel but decided to just go with 93 which cost me 15 bucks more for a full tank ughhh.
I've got a 2014 Focus 2.0L flex/fuel vehicle, non-turbo charged. We want to maximize mileage with E85 or E100. Do you already have an SCT tune that we could have or buy?
Thank you so much, Don Siefkes, 586-596-4765
Tom, while I can't speak for the US, here in Canada, while very limited supply and availability in some areas, the quality of the E85 seems very good and consistent...I know a few guys trying out a local E85 tuner and going to a dyno day so ill post some dynos with the results (previous dynos done for comparison sakes)
I got him going on E85 and had some great gains at WOT , he is looking for MPG so that will take time to check , He has DCT and adjusted that for him as well
So has anyone actually dynoed the difference from 93 tuned to e85 tuned? I see a lot of people doing mods but no dyno or track times to see if it actually did anything.
There's a thread here with E85 Dynos. dude gained like 5-10Hp straight up with pump E85, no tune. I know it's somewhere in the TIVCT performance section. It makes a difference.
You want to build a race car with much more power run off pure alcohol. I think its senseless, i built mine to be optimized off 87 octane, i wanted a little more power but im not trying to build a race car with it, it is my daily driver. But getting an extra 4-5 lbs of boost is nice. 87 octane has more btu's and is more efficient. Higher octane misfires more so the boost can go higher which wont as likely cause detonation and blow a hole in your piston. Thats why you do not want to put 91 octane fuel in a car tuned for 93 octane, unless you want holes in your piston....
That's not correct. Higher octane is less prone to misfiring as it is harder to ignite. Lower octane is easier to ignite and is therefore more likely to ignite before the spark plug fires. The PCM and knock sensor retards ignition timing within it's range of authority when it heard the tell tale signature of knock and pre-ignition.
87 Octane might have a few more BTUs worth of energy but it will pre-ignite easily and therefore is less suited for making power. 93 octane will allow for advanced timing within its range of authority making more power before knock rears its head.
Suss is right, i had different thoughts about low and higher octane gas and the timing. I was wrong, i get it, it happens. I read a lot of different stuff about it last night after reading a lot of forums, web browsing blah blah blah. Sooooo .i. to you too mr.bulls***
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
