First oil change since FF11 when I changed my CV axles, and I have a passenger side axle leaking. I'm going to double check some other stuff today while the car is off the ground, but I'm sure I'll end up replacing the seal soon. At least the transmission isn't whining- so that's good for all things considered.
AFAIK I must've either damaged it when I put the axle in, or it was just it's time at 135k miles. I'm just curious if other people had the same problem. It could be possible that the axle isn't in far enough also, and that's what I'm checking today. I do see what looks like a groove on the axle where the seal should ride just barely poking outside the transmission, but I can't remember if that's normal or not- I'd assume not. I might have to drain fluid, pull that bitch and replace it if it won't go in further. It could be built short.
Comments?
Comments?
