1 - 6 of 6 Posts
I have a standard whip antenna on my Ford Focus.
I live between two radio reception areas.
Is there any antenna that fits my Focus that pulls-in better reception?
BG
They will tell you they will but commonly it works no better. So much depends on your location in relation to the sending station(s) and how much power they are willing to pay for. Common now to throttle back to make more station profit, why many stations that seemed stronger in the past are now weaker.
Antenna Reply...
Thank you!
I'm also thinkin' of getting a newer radio.
Maybe a Shaker by Ford or a Sony.
Thoughts?
BG
Thats What She Said
Well you can do all sorts of things. but may require more technical background and work.
The easy way woudl be get a radio and shop around to look for receiver sensitvity.
https://www.crutchfield.com/S-QLY7vHXAbEq/learn/car-cd-receiver-buying-guide.html
https://www.electronics-notes.com/articles/radio/radio-receiver-sensitivity/basics.php
You will want to make sure you have good grounding and a clean power source as it can add noise.
If you find an antenna that is close to the 1/4 wave length. Example 96.3 MHz is 3.113 meters for a wavelength, so a quarter wave length is 0.778 meters. This antenna will be better tuned for a specific station.
You can also wire in a Low Noise Amplifier in line and a filter but that gets more crazy. I can tell you how and where to get things but you also run risks to damage to the radio.
Something like : https://www.minicircuits.com/pdfs/ZX60-P103LN+.pdf but this is a 5.5V part so would need to regulate down to the correct voltage and get the correct adapaters. also would want a filter at the output of the amp liek Tin Lee Electronics :: FM Products.
This opens a whole room of options and then also may restrict AM operation and other things. but there are ways... but likely cost more than the radio it self.
A more expensive radio can help, typically you get a better tuner that can pick up weaker signal better. Dunno if anyone still sends analog signal but it receives easier, digital is better but a more complicated signal to sort out with no errors. Like said, a powered antenna amp can help but $$$$$$.
1 - 6 of 6 Posts
