alright well i have posted questions about this issue, front right hand suspension BANG!!!, and have had alot of responses such as try prying the sway bar with a huge pry-bar, or loosen the bushings and lube em up maybe they are sticking, and i have had few other suggestions. i have narrowed it down to the fact that sway bar link bolts are hitting the frame of the car when the sway bar activates on the right hand side. My question now is, is there a possibility that the subframe isnt aligned right wich caused the sway bar to not align right. when i take everything off and activate the sway bar by hand, on the driver side i have about 2 inches+/- of clearance between the body and sway bar but in the right side it is hitting dead on. BTW you cant pry the sway bar at all because it has a stopper on the bar that disables movement from side to side.
i really hope someone can give me some direction with this issue, hopefully there is a ford tech somewhere on here with some first hand insight, or even a well informed DIYer. [bawling]
