1 - 20 of 116 Posts
Okay here it is... My 2007 ford focus 2.0 has broken the drive belt idler pulley bolt again.. First / original bolt broke at 50k. Sheared off at the block... I replaced the pulley and tensioner as well just incase that is what caused the bolt to break... 2-4k miles later it broke again..talked to another tech at our ford dealership and he had the same thing happen to his focus... His is still breaking them too.. Then I decided to replace it again and upgraded bolt to grade 8 in the metric system... Also used lock tight and nut from the back side incase it was backing out an causing it to break off.. Well it broke again today 3-4k miles later...it always happens on start up.. I hear a squeal pop the hood and see the broken bolt.. Ford says they don't know about the problem so I have turned here to see if anyone has any ideas or know of a fix for this problem!!!
I hate to say it but if this next time it's not fixed for good I will be trading in on a new fusion!!
Adam Olson
Ford Master Tech
Adam, I have 07 Fusion and have am having same issues. Mine has broken 5 times! Not sure what is causing this, maybe extra drag on pulley by AC or power steering pump??? I tried putting nut on back of bolt with no luck. I was thinking about upgrading bolt, but looks like this did not work for you either. Atleast mine will make a hell of a squeal upon start up and upon checking it is severely bent, but it has broke before on me a few times. I believe the bolt is way too weak. Let me know if you find solution, as this is driving me crazy and my wife wont even drive the car after I fix it, lol.
The ford engineers said that wear to the front cover where the idler bolts down will cause repeated failures... Mine has the slightest marks so I will be replacing the front cover.... If this doesn't fix it I am done!!! The real question is why did the first one break?? I will let people know in a few thousand miles!!
Hope this works out for you.
I know this would just be a bandaid and not address the real problem, but you could always upgrade to a grade 12.9 bolt. I am pretty sure the sheer strength is about 30,000PSI stronger than a grade 8 bolt.
Anyone know where to find this grade 12.9 bolt?
Since you're in Washington. Try Tacoma screw. They have several locations around the sound. Fastenal is also a good source, but tends to be pricey. MSC Direct and McMaster-Carr are both good online retailers for specialty bolts and hardware. Finally there is ARP. I'm sure they've got something that's stronger than grade 8 in your thread.
Mine just broke also.
My idler pulley bolt just broke last night. It's the original at 133,xxx miles. I guess I am lucky for it to last that long. The dealer wanted over $1,800 to fix it! I said frack that, I'm having my own mechanic do it for 1/10 the price.
Old Phart
What was the list of damages to drive up the repair estimate so high?
I assume it's more than just pulley/bolt.
w/ my magic bag
What the heck is going on w/ these bolts? Fatigue or what?
They said they had to remove the engine and weld extractor to remaining portion of the broken bolt. [???:)] I said, no.
And I have to correct my mileage, it's 153xxx miles.
I don't know, but the bolt itself is not very beefy. Not sure of the thread size. It looks like it's smaller than 1/4-20, maybe M4? I'm just surprised it lasted more than 150k miles after reading all the posts here.
Old Phart
Slot instead of hole was the reason I mentioned that thread, it's a nut & bolt deal instead of a bolt threaded into the casting.
Should make removal/replacement a bit easier.
Yeah, I see the slot in the picture. It's exactly what I see on mine. So, there is a nut? Would you guess the nut is still there along with the broken piece of bolt?
Old Phart
Could be, one of the BEST cheap tools is a mechanic's folding/extending mirror to see into all the tight places you can't otherwise peek into.
Second only to magnets of the same type & a grabber tool for things the magnet can't get.
I'd rather be short on wrench choices than without those tools.
There isn't a nut. The bolt just threads into the block. My bolt broke about 1000 miles ago and just broke again today. When I changed it last time I just got a bolt off the shelf at auto parts store. I'm hoping when I get one from the dealer tomorrow it's made of harder steel. Also I'm changing idler pulley and belt this time. Last time they didn't have them at the parts store I was near when it broke. It sounds like this is a problem item. I'm getting good at it now. Had everything apart in less than an hour. Will put it back together tomorrow. Doesn't suck!
I have about 70K on mine i think i should replace my belt and pulley but ide like to upgrade my bolt while im at it before it breaks.
Where can we get those heavier bolts at?
w/ my magic bag
If you don't have any issues, I wouldn't touch it. If it needs a belt, do that only. Why mess w/ it unless you need to?
Good point it could break while im trying to change it
1 - 20 of 116 Posts
