1 - 10 of 10 Posts
battery is not charging and have a smell and noise coming from the alternator. it is a new battery(1yr) so i am guessing alternator. any suggestions and tips on replacement.
my car breaks!
i have a stock alternator i can sell to you super cheap, i know it works i'm using it now :p i have a high output one i need to put in.
i can also tell you everything you need to know about changing the alternator.. as i've done it 6 times (i tend to blow them up with my amplifier and sub)
Discussion Starter · #5 ·
thanks but i live in toronto and i want to get it fast.plus i will have to pay for boarder cross shipping so i might as well buy it here
my car breaks!
ok, no problem, you can get them at any parts store thier about $180 USD so probably $240 CAD
Discussion Starter · #7 ·
alternator problems
i am still looking for ideas about whether it is the alternator or not. as i said before, the battery in not charging and there is a smell and noise coming from the alternator.
my car breaks!
chances are, it IS the alternator, you can change it in under an hour if you know what your doing
Heres a quick way to tell if it the alternator or not. check your battery voltage with a multimeter while the car is off. you will have probably in the range of 10Volts DC - 12vdc. Now start the car up, and the battery voltage should read in the range of 13.5vdc-14Vdc. Most of the time if your alternator is out you wont see any real change in the voltage or you might see a light drop in voltage. Also there is a company on ebay thats selling 170amp alternators called "LOAD BOSS" So far it has put up the best fight with this system has a lifetime warranty too. it lasted me 10 months before draining the life from it.
Can you show me the 1 hour way of pulling and replacing this thing? I'm on my fourth now due to my stereo (2500watt). I've now got 2 alternators that have lifetime exchange so when one blows I slap the other in. heh.
my car breaks!
anouther way to test your alternator is to start your car and unplug the battery.
if the car dies your alternator is an 8 pound paper weight
1 - 10 of 10 Posts
