1 - 7 of 7 Posts
hello all. pretty sure the voltage regulator in my alt is about to die so im just gonna replace the whole damn thing. i realize that ford and all its wisdom and glory decided to mount it on the bottom of the engine[duh] anywho what is the best way to get at it, i would really like to avoid moving the engine around if at all possible
Hatch Nation #136
You're going to have to move the engine around. There isn't really any way around it. Luckily, if you have stock motor mounts, there is a ton of play. Just make sure you put a piece of wood between the oil pand and jack and you'll be good.
You may want to monitor your charging system voltage before replacing the alternator - unless of course you have 150k miles on the original alternator and you have check for wiring problems.
Some parts stores/retailers, with competent staff, have the means to test your system (their interpretation may be another story).
Or - you could enter the instrument cluster test mode and monitor the battery voltage yourself - from initial cold start up to, high rpm warmed up conditions. And verify this with a meter right at your battery.
Discussion Starter · #4 ·
well here is my issue everyonce abd a while the battery light will come on the engine will stumble abd then all will be fine. but it has become more frequent and the bat light stays on for a lil longer. this happens at random times having no correlations with starts and what not
All you really need to remove is the passenger side motor mount in front of the timing cover. Takes a few minutes to remove and that should give you all the movement you need. I replaced my alternator a few months ago, it came out from the top pretty easily with the motor mount removed. I don't see any other easy way to get it out. I looked from underneath and I couldn't see any place it would easily fit through.
Are you working an a Zetec or the DOHC Duratec?
My battery light just came on, and using a voltmeter, the alternator is not charging. Mine is an 04 ZTW wagon with the 2.3 DOHC Duratec, and the alternator looks like a total PITA to remove! It's mounted right in the back by the exhaust manifold, and I don't see any possible way of it coming out the top. Any tips on removing and installing a Duratec alternator?
Thanks!
Hatch Nation #136
Thanks!
He's running a Zetec. It is the SVT.
1 - 7 of 7 Posts
