1 - 4 of 4 Posts
Hello;
I've got an 02 SVT that I'm having charging problems with.
I checked the voltage output on gauge cluster and it seems fine at 13.6 when nothing is on.
Then when I turn on the AC is drops to 13.0, and when I turn on the headlights it drops to 12.5.
When I', warming up the car in the mornings and defrosting the windshield it will drain all the power.
Is this a faulty alternator? I kinda thought the alternator either worked or didn't.
Sounds like it could be an alternator problem ecspecially if it charges good at first then kinda peters out or vise versa
I don't want to replace the alternator, since I'm worried it won't fix the problem... What if I have a bad ground? It seems like it could be a bad connection. What do you think?
1 - 4 of 4 Posts
