i have a 04 svtf and sometimes the car wont start on the first try of turning the key but sometimes it will. then sometimes it wont even try to turn over. (the engine)
well today i drove back from abilene to arlington (tx) about 2-3 hour drive.
and when i'm taking the exit i need to take to get home i push the clutch in and put it in neutral. well while coasting to the light about 1/2 mile or so the car dies and i'm just coasting. power steering stops and powerbrakes. and the battery light comes on.
well when driving to my dads the car (in neutral again just coasting) the car dies. and did this again in the drive way of my dads.
i have a ford motorcraft battery and the battery is still good (got it tested at pepboys)
but the guy said if it was the alternator that was bad the battery wouldnt be as charged as it was (battery rated 590cca and it tested 550cca)
all i can think then is the 'chip' key that ford uses so you cant get your car stolen. i'm wondering if there might be a miscommunication with the key when its in the ignition maybe.
idk.
if you have any info, please help
idk.
