1 - 2 of 2 Posts
Do shops know to adjust camber with aftermarket camber plates? Just wondering because I need an alignment and have camber plates and wasnt really sure if a normal shop would even look their for adjustment.
Other question is what specs should I tell them to dial me in at, because I am really clueless when it comes to the adjustments? I want some more negative camber because I have some rubbing issues, what is the maximum amount of neg that I can safely run?
Thanks!
Adam
No they wont know you have camber plates. You have to tell them. I would suggest -3 toe out front and 0.02 toe in rear with -1.1 rear camber.. idk about the front camber.
You dont want a lot of camber it will eat your tires up. Where are the tires rubbing at? if its the iner finder just cut it a little bit, it solves the rubbing and no one can see where you cut it.
1 - 2 of 2 Posts
