1 - 4 of 4 Posts
1.0 Powa
I will be installing my suspension very soon and was wanting to know what I should have the suspension set at. Thanks. Car is a 2000 ZX3 if that helps any.
You need specific settings to minimize tire wear. A simple search would have found them as well. ASK for the following numbers otherwise you won't get them:
Front camber - anything within spec (it's not adjustable and is tolerated)
Front caster- not adjustable
Front toe- 0.01 to 0.02 inches max. (OUT)
Rear camber - minus 1.5 degrees max. (it's not adjustable as well, but if you're over this spec, you'll need a camber correcting devise to reduce it)
Rear toe - 0.04 inchs max. (IN) - this is the SVT rear min. toe-in spec and recommended for non SVT lowered cars as well.
1 - 4 of 4 Posts
