I'm with Geezer...check your suspension components.
That's a HUGE amount of camber for only 1" drop.
Something's got to be bent.
How even is the camber from side to side?
Is it really -3.5° on both left and right?
Are you guessing, or have you had it to a shop, and can show us a printout of the alignment settings?
EDIT...after mulling over the subject for a bit...
The LCR plates (which I have) should allow you to reduce the camber by a little over 2°,
but check your components to see if something's bent first.
If you've got stock upper strut mount/bearing retainer plates, and only 1" lower, you should be nowhere near -3.5°.
I'm sitting at -2.1° with Koni springs. (about a 1/2" drop over stock SVT springs),
and that's with the plates cranked in as far as they'll go without hitting the strut tower.
