Got the camber bolt in to match the left side to the right at about 1 degree negative. Ran the car to the local tire store for a quick check
Everything in front was where I wanted it.
Rear camber was now about 1 degree neg each side but toe was 0.25 degree left and 0.14 right. I asked the guy to set the individual rear toes to as close to 0.04 degrees as possible. HE came very close......each individual rear toe was now in individual range (at low end) but the TOTAL rear toe was out of spec at 0.08 (to a min spec of 0.18 degrees)
He didn't want to leave it that way but said he would if I noted it on work order and receipt.
So now I have 0.04 degrees toe each rear wheel and 1 degree neg camber. Felt fine during long drive home. We'll see how it goes! Thanks for all the advice!!
