1 - 5 of 5 Posts
I just fixed up my 05 focus however I can't figure out the airbag light. I just replaced the airbag which didn't completely go off. Any suggestions? Do I need the airbag restraints? The airbag sensor is located under the passenger seat.
sometimes if the airbag sensor comes loose underthe passenger seat, the airbag light will come one. check the sensor.
Discussion Starter · #4 ·
Yah it was in a fender bender. The airbag didn't even come out, it just broke the casing. I just replaced the aribag module under the console. However the light is still on. Ford says you have to reset the comp. 160 dollars to do that.
Im 1000 dollars into this airbag replacement. Even with my discount.
these cars should have seatbelt tensioner that would also have to be replaced from a fenderbender take it to an independent shop they should be able to scan it allot cheaper, and tell you If anything else should be replaced.
some manufatures also specify that the clock spring must also be replaced but that may just be dodge.
1 - 5 of 5 Posts
