See many airbag light codes. Have many codes, none to do with airbags. The light is on, on the dash. Just got the car.... Really cheap. May have been in an accident. Can I reset it?
The code will be based on the flash pattern of the light during start up. it typically is a series of blinks such as 1 then 5 or 2 then 3.
Check the connections under the seat for easy things to look for and it isn't uncommon for the clock spring behind the airbag to go bad and cause an airbag code.
Related Threads
Focus Fanatics Forum
5.8M posts
189.4K members
Since 2003
