1 - 5 of 5 Posts
See many airbag light codes. Have many codes, none to do with airbags. The light is on, on the dash. Just got the car.... Really cheap. May have been in an accident. Can I reset it?
FUBARCUS
2003 ZX3 2016 FoST
The code will be based on the flash pattern of the light during start up. it typically is a series of blinks such as 1 then 5 or 2 then 3.
Check the connections under the seat for easy things to look for and it isn't uncommon for the clock spring behind the airbag to go bad and cause an airbag code.
  • Like
Reactions: pbfoot
The connector to the clock spring can get knocked loose as well.
Need to see the codes for some direction..........if car has been in accident to write to the bag module it may have to be replaced/reflashed.
1 - 5 of 5 Posts
