Thanks for reply just getting module reset now and hopefully will start car ok then if any codes can clear themIf ANY airbag went off the airbag module must indeed be wiped and reloaded with specs. They write to the module when bags go off and your original info is then lost and the module disables itself.
Thanks this makes sense as the car did start up after it was all put together but ran funny so maybe was the last bit of fuel getting through ?The error there is pointing to antilock braking (ABS) which has nothing to do with airbags. ABS does not stop car from starting either.
Like said check for a fuel pump (inertia) shutoff relay, most of the cars have them, and it definitely stops car from starting up. It's a circuit breaker that you simply push button on to reset back to working.
