I've seen modules that you can connect to your car and continue to use the factory remotes to start the car. In most cases, you press the lock button three times within like 7 seconds or something. Anyways, I was wondering if any of you have done that, how difficult is it to install, and also does it put the car in "run" mode, the EXACT same way putting the key in would? I understand it's gotta be in run mode to run (duh) but will it also trigger the ACC lines throughout the car? I've got a usb charger for my Cardroid that I'd like to start up at the same time, and it's hooked to an ACC line.
Thanks in advance!
BTW, the one that I'm thinking of getting is something like this>
http://www.ebay.com/itm/271388006857?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
Thanks in advance!
